brooklynblue
Everything posted by brooklynblue
  1. I know this topic is a little old as far as the post date. I have a 02 boxster and I had a issue with it recently. I parked the car for 2 days without using it. I came back to start the car and my remote to open the doors wouldn't work. My interior lights were gone on the door panels and the overhead light. The dashboard lights were lit up like they normally would be but, when I turned the key in the ignition the car wouldn't start at all. No sound. I had 2 solid bars where my sensor would normally blink. My trunk and rear hood wouldn't open either. If someone could give me some advice, I would greatly appreciate it. Door: The trunk and the hood releases on a '97 are mechanical, so those are unrelated to your dead battery or other electrical problems. Do a search here and you will find instructions on how to open the hood and the trunk without using the releases so that you can inspect the operation of the release cables. If both windows don't work, first check the fuses in the fuse panel located at on the left kick panel, just to the left of your calf when sitting in the driver's seat. If the fuses are okay, then it's either the switch(es) (unlikely that both went bad at the same time), or the central alarm control unit under the seat. There is also a 15 amp fuse located at the back of the control unit. Regards, Maurice.
