ProV1
Everything posted by ProV1
  1. are 01+ TT brakes & suspension parts compatible in 99 C2? ne1 know how much larger are TT brakes vs C2s' and how much lower the stock TT suspension is? TIA!
  2. is that whole plastic above the carpet 1 piece, or can the handle and piece below the airbag be removed separately? how hard is teh install? also can the carpet on the door be replaced? is it a simple swap?
  3. 1. what are porsche recommended intervals on these items (for 99 c2)? a new porsche owner, still learning about porsche world. thx and c y'all around!!! oil change (for a <5k miles/yr car, once a yr or once 2 yrs?) brake flush coolant flush microfilters fuel filters air filters 4 wheel alignment 2. what are exactly done in these services? some sound redundant. should all be performed? yearly service 15k 30k 45k etc services 2yr 4yr 8yr 10 yr services 3. what are the most commons "failure" items on early 996s, and how many miles do clutch, brakes, spark plugs, thermostat, water pump, radiator, fan clutch, suspension parts, battery last? are 996s known to have a weak clutch? thanks all for insightful help. it's nice to see so many diehard fans. btw i truly believe that w/ reg maintenance and TLC these 996s can last easily up to 150,000 miles or 20 yrs.
  4. hello, can u rate these mods 1-10, 10 being the hardest? and are there online instructions on these, preferably w/ pics and geared towards novices? (have done oil change on non-porsches but that's it) steering wheel replacement (does battery need to be disconnected?) rear console replacement shifter/park brake replacement AS interior trim pieces replacement oil change on 99 c2
