Ds996cab
Everything posted by Ds996cab
  1. Where are the screws on the Drivers Door Panel on a 1999 996 Cabriolet. I believe their are 5 of them but don't know where they are. Also, the reason I'm removing it is to remove a stopper that is keep my window from going all the way down. It stops with just an inch or so left stinking out. I had the car repaired out of state and can't take it back to the person that installed the regulator in the first place. Any pics of the stopper would be super helpful or maybe a hint as to where it will be once I'm inside the door. Thanks
  2. Labor is is pretty easy on it. My brother is a Porsche Tech and I have the instructions on how to replace it. Doesn't look like the pictures came thru sorry. It sould take about an hour. Per side. If you do replace both and the passenger side is still good, I'll buy from you. My passenger side is leaking. Removing And Installing Hydraulic Cylinder Removing and installing hydraulic cylinders General remarks on hydraulic system The hydraulic system is sensitive to penetration of dirt. As soon as the system is opened by the plug, a cloth must be placed under the hydraulic lines to catch escaping hydraulic oil. The hydraulic convertible top uses a closed hydraulic system. In general, the hydraulic system will need to be filled only if the hydraulic circuit was opened (after parts replacement). Only Original Porsche hydraulic oil must be used when changing or topping up the hydraulic oil. Opening and closing hydraulic valve of the hydraulic pump Access for opening and closing the hydraulic valve up to model year 2000 To open, insert the Allen key -A- into the hydraulic valve -B- and turn approx. 1 turn to the left. To close, insert the Allen key into the hydraulic valve -B- and turn to the right. Access for opening and closing the hydraulic valve as of model year 2001 To open, insert the Allen key -A- into the hydraulic valve -B- through the bore -X- of the roll-over bar module and turn approx. 1 turn to the left. To close, insert the Allen key -A- into the hydraulic valve -B- through the bore of the roll-over bar module -X- and turn to the right. Filling the hydraulic system It is essential to lay a cloth underneath the hydraulic pump when filling. Do not fill above the "Max" marking. Filling the hydraulic system up to model year 2001 1. Unscrew plug. 2. Fill system only using Original Porsche hydraulic oil. 3. Screw in plug. Tightening torque: 10 + 1 Nm (7.5 + 1.0 ftlb.) Filling the hydraulic system as of model year 2002 1. To fill the hydraulic system, the bracket with the hydraulic pump must be removed. Refer to "Removing and installing hydraulic cylinders". 2. Unscrew plug. 3. Fill system only using Original Porsche hydraulic oil. 4. Screw in plug. Tightening torque: 10 + 1 Nm (7.5 + 1.0 ftlb.) Bleeding the hydraulic system CAUTION: Damage to the convertible-top frame it not running synchronously. • Bleed the hydraulic system only after the hydraulic cylinders have been removed from the convertible-top sup- ports and drive levers on the left and right. The system has a self-bleeding feature. Three to four operations will bleed the system. After bleeding, check the oil level in the container on the hydraulic pump and check if necessary. To bleed, the hydraulic valve must be closed. Refer to "Access for opening and closing the hydraulic valve up to model year 2000" and "Access for opening and closing the hydraulic valve as of model year 2001". Line routing for replacing the right hydraulic cylinder as of model year 2002 Warning: • Damage to hydraulic lines. Do not bend, trap or crush hydraulic lines during installation. • The spare hydraulic cylinder has hydraulic lines approx. twice the length of the standard component and can be installed on both sides. To prevent damage to the hydraulic lines caused by bending, trapping or crushing during installation, line routing has to be consequently carried out. 1. Wrap the hydraulic lines around the support of the frame for the roll-over bar 1x. Fix the lines with a tie wrap -arrow- . 2. The lines should be free of tension and twisting when connecting to the pump. Observe allocation of the hydraulic lines! -Blue, red- , refer to "Removing and installing hydraulic cylinders". Tightening torques
  3. If I want to check/refill the fluid on the hydraulic convertible top, is there a way to manually drop the top on a 1999 996 cabriolet? I may not be able to open it for the service.
  4. I've checked the basics.....lid is shut, brake is on...etc. Here's what it's doing. First sign of issue: It came down kind of slow and sloppy. Second sign of issue: It came down with a jolting motion…..move-stop-move-stop-move-stop….etc Third sign of issue: It came down with a jolting motion and stopped half way. Fourth sign of issue: The back of the car opens and the top unlatches but doesn't move at all. Right now the back opens and it unlatches but doesn't move. I "can" hear the motor trying. During all of this the top will close with no issues. Any thoughts? If you have a diagram, I may be able to open it up and see if it's off a track or something. Thanks for any help. Ds
