tone01
tone01's Achievements
  1. yes my psm and abs lights are on too it has a rough idle in the low rpm range. the signal off the maf the blue/white wire. i checked it at idle its 1.2 volts and at full open throtle it goes up to 1.8-to 2.0-2.1 around there. i checked all data it says at full open it's should go down in volts around .9 volts or so.is that correct brake lights work . i'm on my third maf
  2. oh sorry its a 03 996tt
  3. hi every one i'm having this error code p0102 it say low circut maf. i changed the maf twice, check for bad ground everything good, check if there were any breaks in wires with omh meter no breaks /does any one have any advice what the next step would be. i used the scan tool and the reading on the maf at idle are around 3.5 grams is that normal one guy i talk to said it should be around 18-20 at idle. any help would be great i'm really stomped. thanks every one
  4. was woundering if any body has a step by step on how to change transmission searched form but could find anything step by step any help would be great thanks
  5. was searching the fourm looking for a diy step by step transmission change found some but nothing really detailed. was woundering if i needed any speciality tools and any other problems i should look for. any help would be great thanks
