kodas
Everything posted by kodas
  1. Thanks I will check but it has been dry here the last couple of weeks with no rain. I will see if it happens after washing also.
  2. Wow no one has seen this? Is there a relay that controls the sunroof that may be failing?
  3. My sunroof has started to randomly open to the pop-up position while driving. Has anyone seen this problem? This has happened twice in the last week without anyone touching the sunroof controls.
  4. Thanks I believe that was my problem. That is the sunroof drain and it apparently was not seated good enough in the hole. I tested by pouring a little water into the sunroof front passenger side drain and nothing came out under the car (leaked inside). I pushed the hose fitting firmly into the hole and tested again successfully with water draining outside behind wheel well. Thanks again for your prompt response.
  5. I have the MoBridge with Bluetooth. Both phone and IPod work fine. The iPod navigation is not as slick as just using the click wheel but if you keep your playlists updated it is easier to navigate to your favorites. Searching through artists or albums is tedious as it is alphabetical.
  6. I have searched on this topic and believe that my drains may be clogged or disconnected; however, I have not found a good description of the location and how to either clean or verify it is properly connected. Please help with a good description (pictures would be great) of the front passenger drains and how you get to them to clean or check for proper connections. Thanks I would like to rule out these drains before I call the windshield guys.
  7. After installing a Mobridge Ipod/bluetooth each time the PCM starts up I get a "Cd changer not found" error message. Is there any way to program this out? I know that the Mobridge is installed via the Cd changer connection but can this annoying error be fixed without affecting the Mobridge?
  8. After removing the A/C cover I found one drain hose that was connected and passing through the firewall. It was in good shape and I did remove it and ran some water through it to make sure it was not clogged. Is there another possible source for the water on the passenger side? another drain hose?
  9. Please help having the same problem with my 06 Turbo s, the passenger side floor mat is soaking wet. Any diagrams to show where these drains are located. Do I have to pull anything apart or is it visible from under the dash?
  10. Thanks for the input, I will post an update after I get it done.
  11. I have an 06 Turbo S with the Mobridge Ipod/Bluetooth and want to know if I can do the NAV/PCM update without affecting the Mobridge?
