BlackBear
Everything posted by BlackBear
  1. When I go in and do the settings for Summer Tires it tells me setting complete. Then I get just bars on all for corners. After about one hour of driving it says TPMS inactive. What is the problem? The 2006 C4 Cab is just out of warranty. Are there batteries in the sensors that could be dead?
  2. Thank you again Loren.
  3. What are you trying to do? Hook up a shift light? Both the speed wire and shift monitor wire have been discussed here before. I bought a Pioneer F900 Nav and will be installing it once I figured out all the wiring. I remember from my XM modulator install that there are several plugs into the PCM. I don't want to have to reinvent the wheel for all the wires I need. In the 997 the VSS can be taken from the ABS computer in the trunk. Is there a better way for a 996?
  4. Loren, Do you by any chance also have the wiring diagram for a PCM 2.1 with MOST fiber optic Bose? Is the VSS wire, Speed sensor, wire in this plug or does the unit get this signal from MOST? I have a 2004 Turbo Cab. Thank you.
  5. Loren, Thank you. You made not only my day but also my weekend. Thanks again.
