rdragon
Everything posted by rdragon
  1. hi, i've always put in chevron gas and just the other day i was forced to put in arco (i was running low), so i only put 3 gallons in...hoping this is only a coincidence. i noticed the following day it hesitated starting and now today it won't start at all. anyone have any ideas? when i turn it over, the windows go madly up/down (not all the way, but like when you normally open/close door). are there any checks i can perform to rule anything out? thanks in advance
  2. thanks. i found out that the 996 upgrade is ~20k+ but that the upgrade of a boxster s 996 conversion ~32k+.
  3. hi, wondering if anyone knew ~ how much this conversion cost? thanks.
  4. thanks again. loren - that would be great and sounds interesting/fun, but unfortunately i live up in wa... would you happen to know anyone up in seattle area that holds work on car days?
  5. thanks. what if i do just the oil change at 30k and not the actual 30k service? is that not recommended? the difference in cost seems to be ~ 200ish vs 700.
  6. adsach - thanks for the info, had no idea how much it cost. they charge 175 out here and i guess that is in a similar range...
  7. hi, ~ how much does this cost? thanks.
  8. also, is it truly required or can you skip it and do the 45k? any inputs appreciated.
  9. Hi, approx how much does this service cost? thanks.
  10. the remote control goes into standby within 5 days to prevent discharging of car battery. if this happens, you unlock manually, leave door closed, and press button 1 (the main button) and it will be activated.
  11. mine does not run as well in the beginning on a cold day as well. is that normal and why is that?
  12. highlander - thanks. that's what i assumed but wanted to get a feel...
  13. is it correct to assume most don't tint convertibles? thanks.
  14. hi, any of you tint windows on your boxster? if so, (for 2002 and older) do you get the plastic window tinted as well? does it look good or bad? thanks.
  15. i see. thanks for info. i seem to get my "howling" noise when driving in 2nd or 3rd gear intermittently...
  16. i am interested in the conversion as well but i heard going from plastic to glass requires a lot of effort. for those who have done this, are you doing it yourselves or through a dealer? i understand that the whole mechanism is different
  17. ptec - what do you mean after a drive cycle? thanks.
  18. westwood - can you describe when you get this noise? i am experiencing some noise as well and never knew how to describe it but it does sound like howling (a bit).
  19. simonpbs - i see. is it a safe conversion? do you have any info on it? i'd like to get the glass rear window as well, but dealer says it's a very difficult switch. did the dealer install for you?
  20. hi simonpbs - i may have missed a thread you had previously on this... what prompted you to get a new top? to have the glass window? thanks.
  21. thanks for your responses...i'm getting it checked out
  22. hi, i hope someone can help me out. i've been hearing a weird rattle noise in the engine area so i made an appointment tomorrow to get it checked up. however, as i was driving back home today, the noise stopped and the battery warning light came on. steering became real difficult (luckily this happened as i was turning into my driveway). so in reading the manual it sounds like the drive belt is broken. is that correct? if so, is this a major problem? can i still drive it to the dealer tomorrow morning?
  23. ok, thanks everyone. i'll look for it at local dealer first...
  24. thanks. where can you find this plexus product?
  25. hi, for those who have the plastic rear window - what do you clean it with?
