Bradster
    Richmond, Virginia
    1997 Boxster
    1979 928
    1974 911
    1988 944
Bradster's Achievements
  1. Thanks for your help. I really appreciate the advice.
  2. Thanks, DC. I'll keep an eye on it to see if issue worsens.
  3. On occasion, and usually when I start the car cold, I'll get a burst of blue smoke. After the initial burst, it goes away and it may be ten starts before it happens again. No smoke while running. Again, this happens only occasionally. I assume that bit of oil is getting by the rings, but why only once in a while? Any ideas? Some have suggested a failing AOS, whatever that is. Thanks. 97 Boxster, 79,000 trouble free miles (so far) Bradster
  4. The v-bracket snapped. In stead of opening, the top continued to close until there was enough pressure to snap the v-bracket. I am lucky that is all that broke. I think the problem may be with the b-pillar switch, but who knows. Anyway, thanks.
  5. After lots of time and some expense, I am convinced that I will never get the top to operate properly without spending a fortune. I have tried everything with the help of many at various forums. Even the mechanic at the local dealership said that the tops should just be operated manually. It's very easy to do, except for one thing -- securing the clam shell tightly over the open or closed top so the seals are set. Has anyone ever come up with a way to manually secure the clam shell tightly? Also, is there a way to shut off the idiot light on the dash? Thanks.
