knut grave
    Norway
    Porsche 993 gt2 evo
knut grave's Achievements
  1. Yes the car has had a small kolisjon inn the front.. where on the car can i find the fuel pressure sensor? knut
  2. Thanks is it possible that som of these foult codes cause the fuel pump not to start? Knut
  3. :welcome: (DTC 99) P0450 Tank Pressure Sensor - Signal Implausible P0452 Tank Pressure Sensor - Short to Ground P0453 Tank Pressure Sensor - Short to B+ Possible causes: - Pressure sensor faulty. - Short circuit to ground. - Short circuit to B+. (DTC 96) P0447 EVAP Canister Shutoff Valve (Output Stage) - Open Circuit P0448 EVAP Canister Shutoff Valve (Output Stage) - Short to B+/Short to Ground Possible causes: - Wiring harness - Shutoff valve - DME control module - Wiring harness - DME control module P1673 Fan Output Stage - Open Circuit One of the radiator cooling fans is not operating. Possible causes: - Break in wiring. - Relay faulty. - DME control module faulty. - Short circuit to ground. - Short circuit to B+.
  4. Hey fault code 99- tank pressure sensor. unknown DTC 1673 fault code 96- shutoff valve activated. the engine will not start, no fuel pressure. it starts when i put 12 volts directly on the fuel pump. Knut
