frodo
Everything posted by frodo
  1. Thanks folks. I swapped the bulbs from side to side as suggested. The bad bulb stayed bad and the good bulb still lit. I appreciate the help. Thanks again, Peter May I ask what bulb you finally selected as a replacement? did you use the Phillips 85122? Thanks.
  2. 1999 Boxster I am trying to diagnose to OBD codes (P1128, P1130) and was checking for air leaks. I took off the hose runing from the oil separator to the intake manifold and noticed there was a small amount of oil in the tube (evident at both ends). Is this normal or is it a sign that the oil separator needs to be replaced? :help:
