frankoo
    BUDAPEST
    Other
    '05 987S
frankoo's Achievements
  1. You can pull off the plastic cover from the front side! But I think you must disassemble the whole seat to change the airbag....
  2. Hi everybody! So, what happened with my car??? After 2 weeks my car works again! THE RADIO CDR24 has a "closure" or cadence and the electrician try to fix it! Now the radio is not in the car and everything (roof, instrumental panel...) works again! When you have the same problem, please remember this! Thanks for everybody!
  3. So this it totally different from the 986, the ignition switch is one block! I took my car to a Porsche specialist, maybe he can find the problem....
  4. Really thanks!!! I try to replace it!!
  5. :) I'm sorry! This is a Boxster S year 2005 (280HP) I tried reconnect almost all plugs, used some spray but still wrong... The battery cables are good, but how can I check the ignition switch? I moved the dashboard plug out-plug in the ignition cable but nothing happened! Thx!
  6. I have a strange problem! Few weeks ago I started the engine but the instrument cluster was totally dark and nothing worked... A day later everything worked again! And now I have the same problem, but the roof doesn't work too! I was driving my car and I saw a little thunder on the instrument cluster and some word maybe "electric" but just for a second and then everything went dark.. All fuses are okey, the Durametric software can't communicate with the car! Have somebody any idea what would be the problem??? Thx!
  7. Hi! I have the same problem like chema, but I heave these errors: 800C Driver's thorax airbag above upper limit -------------------------------------------------------------------------------- C140 Communication timeout Instrument Cluster Control Unit -------------------------------------------------------------------------------- C158 Communication timeout GW Control Unit Anyone could help me, what I sholud repair or change in the car? Thx!
