Vampyre
Contact Methods
  • Website URL
    http://home.rochester.rr.com/vampyres
  • ICQ
  • Interests
    Sports Cars<br>Computers<br>Home Theather<br>Electronics<br>Midi synthesizers
    New York
    Porsche Boxster<br>C5 Corvette<br>Mits Diamante LS<br>Dodge Caravan
    1984 944 LUX<br>1991 944S2<br>1983 Delorean<br>1986 Toyota MR2<br>1991 3000GT VR4<br>1985 Audi Rally Coupe
Vampyre's Achievements
  1. I will check my old post about heated seats. sorry for the repost. Fog lamps The Jumper wire is fine, no shorts as I have stated in the post. it used to work just fine, I am pulling out the light switch correctly also. I think I did check the fuse and it ws fine I'll have to check again to be sure. Thanks For you help!
  2. Wow, I have had a great year driving my 1997 Boxster, but a couple of small issues have popped up. Issue One. My Heated seats worked fine when I purchased the car, now my heated seats are intermittant. If I drive the car for awhile the seats will work. Now it seems that I have to drive longer and longer to get the seats to work. Could this be a relay that is sticking, since when the seats do work they are fine, both high and low settings work well. Any wiring digaram would help and or locations of fuses or relays to check. Issue Two. My rear fog lights are jumpered and both worked very well for a while, I tried them at the end of summer and they didn't work anymore. I check the Jumper wiring and it was fine with no shorts to ground. I also noticed my Front Fog lamps no longer work. I do not know if the front and rear fog lights are independant or they share common points. My regular lights all work fine as does the turn signals any ideas?
  3. I am looking at this www.upsolute.com they are a tuning company and currently offer a chip for the 2.5 Boxster that claims to Stock With Chip ---------------------- 204HP 220HP 181ft/lb 207ft/lb Has anyone tried this chip and if so do you like it. it is available for $300 this is the best price I have seen for a tuning chip for the Boxster, the last one I looked at was about $1200 which seems way out of place when you see what other cars chips are selling for.
  4. The cargo net for the Bocxster is listed as part number 986 551 982 00 Will this net fit into a 1997 Boxster 5 Speed? Is there anything extra I need to mount this net or will the part come with everything I need? Thanks
  5. The Mustang LX is not a 5.0 liter V8 engine. The LX has 2.3 Liter 6 banger, and alot less HP then a 5.0
  6. I have a 1997 Boxster with stock heated seats. they have started to act up lately. When I switch them on they no longer come on, if I drive around for a while they will work. Could this be a relay problem and if so, where is the relay located. Thanks
  7. That is it!!!, the picture you have is what i am talking about, What does that do and can I check to make sure it is adjusted right? Thanks!
  8. When I stop my top in the half way position I noticed these tabs on both sides of the track they can slide forwards and backwards. any idea what these are used for? I can send a picture if needed. Thanks
