Vman
Everything posted by Vman
  1. I just bought a set of 5 spoke 2002 Carrera wheels for my 1999 C2. Does any one know how much the front 8x18 and rear 10x 18 weigh? thanks in advance.
  2. Does anyone know how much lighter a pair of GT-3 race seats are vs. stock 996 C2 seats. I am asking as if it makes the car lose more than 50 pounds it bumps me up a class in Autox. Thanks, VMan
  3. I am getting the car ready for autox, I just had a PSS9 kit installed, huge difference, but have 4 points left to spend in the class I am going to run. The choices are 1) GT-3 Sway bars (2 points) and Pirelli Corsa DOT 60 or Michelin Pilot Sport Cup tires DOT 80 (2 points) in 225 Front 265 Rear (stock size) or 2) Skip the Sway Bars and get bigger wheels and tires 235 F 295 R (4 points) and run regular Dot 220 street tires ie. Michelin Pilot Sport PS2. I am on the fence as a newbie driver some have said less to think about is better ie. worry about adjusting the shocks and get big street rubber on the car as it is more predictable than the stickier pilot sport cup tires or Corsa's. Does any one have any suggestions or have you tried the above setups? I will continue to use the car as a daily driver, however living in SD I am not worried about rain but am worried about soft compound tires picking up every nail on the highway. Thanks in advance. VMan
  4. As stated I the numbers from the bilstein tech down in their factory which is in Poway, CA...if wrong well sorry, but usually I expect a factory suspension tech to have a clue, as I am no suspension expert. VMan
  5. Do you mean the GT-3 front strut mount? Yes the top front strut mount, I am already going with GT-3 front control arums.
  6. can put on the stock 18 inch turbo wheels (factory is 225 front and 265 rear)....Also, if I buy new wheels what is the max 18 inch tires and wheels I can fit on the car? Ideally I would like to put a 235 or 245 up front and a 295 or bigger in the rear, but I don't want to hear a bunch of rubbing and scrucbng. Note - I will be running michelin pilot sport cups for the tire and the car will be lowered 30 mm front and 20mm rear. I have no aerodynamic kit on the car and would be willing ot have fenders rolled if need be. Also, has anyone tried to retrofit the GT-3 front camber plates to a 996? Thanks in advance. VMAN
  7. Got off the phone with bilstein their PSS9 kit is sprung at 260 main + 125 to 150 tender = about 425 front and 525+ tender of 125 = 650 rear...so about the same as the typical moton setup of choice of 450/650
  8. Vman
    Spring Rate on GT-3
    Thanks that is a great post, very helpful
  9. Gert did not have the information on the spring rates, but confirmed that the US and European PSS9 kits are the exact same product. Note - some feel the Euro kit is stiffer. Also, I have heard of some people rigging the GT-3 PSS9 on 1999 C2 996, but have not been able to get much information on this stuff. Note - 260 and 500 on the PSS9 kit sounds wrong as the GT-3 is sprung at 285 lbs front and 385 rear.
  10. Does anyone know what the spring rates are for the PSS9 kit for the 99' C2. A bilstein sales rep told me he thinks they are 260 lbs front and 515 lbs rear. That sounds like the wrong rates, as the ratio on stock MO30 and GT-3 spring rates front to rear is .7 to .75, the rates the bilstein rep quoted are almot .55. Thanks, Vman
  11. Vman
    Spring Rate on GT-3
    Thanks Z06...Can anyone confirm his numbers?
  12. Thanks for the info. On the owner manual....problem is I don't have an owner's manual the prior car's owner seemed to misplace it. I guess it is time for me to buy an owners manual so I don't ask anymore stupid questions.
  13. It depends if you want bling or zing.. 19 inch are great looking, but almost every tuner/race shop I have spoken too has said do not put anything bigger than a 18 inch wheel on a 996, unless you want to really screw your suspension geometry. The wheel and tire size are calculated by Porsche when building the suspension geometry, in fact they are part of your car's suspension
  14. Does anyone know what the front and rear spring rates are for the stock GT-3?
  15. Does anyone know the exact size, offset, and weights of the OE 18 inch wheel for the 99 C2? I think the size is 8x18 E52 For the front, don't know the weight Rear 10x 18 E65, don't know the weight. Thanks,
  16. You can buy the ROW 30 kit from for about $1,000 mail order +$600 to install and align...check the 6speedonline forum for details, the ROW MO30 it is great deal for shocks, bars, and sway bars. You are correct in that it keeps you in the stock classl. I am on the bubble on this issue, as a properly setup 996 with JRZ's, camber plates and adjustible sway bars will cost around $6K installed and the value of your car is reduced as you can no longer sell it as stock. Cost aside, if you ever get into racing the car at porsche club races, you will be allowed to run in stock group C. even with the JRZ setup and you will be able to run one classs up in Autocross (depending on if you get the camber plates or not). Bottomline, for $6K you have a car that in the handling department can clean the clock around most course of a stock GT-3, as while you are down on ponies you have better handling. P.S. as soon as you can ditch those Dunlop tires, I had a set and they absolutely sucked compared the michelin pilots.
  17. :) Okay, I was a mouse click away from buying a ROW MO30 kit for my otherwise stock 99' C2, then I made the mistake of calling a couple of the race shops (TRG, TPC, etc.). Note - my car is going to be used as a daily driver with weekend autocross and track use at least once or twice a month. I don't care about how the car looks (anti-bling), I just want it to handle its best, as such I am sticking to stock 18 inch wheels and will not lower the car beyond ROW specs, even with coil over's. Note - 19 inch wheels and lowering beyond ROW spec , while looking great, has proven to cause handling problems, at least according the experts I have spoken too. So what's the new deal? JRZ, whom for years has created remote reservoir shocks for track use has come out with a new shock, the JRZ RS double adjustable, that has similar dampening characteristics to is double adjustable remote reservoir shock and does not require you to cut your car to install a remote reservoir. The shock can be ordered with a similar spring rate as GT-3 stock springs, so it won't kill you on the street. The a set of four shocks with mounting hardware for my car sells for $3,500. JRZ vs. PSS9 apparently the JRZ's can be dialed up to be much stiffer than the PSS9. In my driving of friends car's lowered with a PSS9 to ROW height vs. ROW MO30 kits, I did not find much of a difference in control, since I don't plan on slamming the car I was going to go with the ROW MO30 kit vs. the PSS9. Note - I have heard that with slicks the PSS9 kit becomes noticeably better than ROW MO30, but am as I am unlikley to run slicks this was not a factor for me. So what is my question? Does anyone have experience with JRZ products? Are these things going to blow up after 6 months of daily driving and make my life hell ( I don't have time to take this car to the shop every other week). Note - I realize they have no warranty, as they are race parts and am ready to selfinsure against that. Does anyone have any experience with this new JRZ RS shock? I hate to be the first one to take the leap of faith. SWay bars...I have read numerous posting about problems with GT-3 bars and the custom drop links needed to make them work with my 99' C2 ? What is the latest on that, in the alternative, what is the best sway bar upgrade, other than porsche bars, that has proven to work without problems on the street (clanks, clunks, or turn restrictions?) Thanks, VMAN P.S. I have attached a picture of the new shocks
