coleta
Everything posted by coleta
  1. Has anybody ever noted the tra/rkat and fra values when an AOS went BEFORE replacement. Can you all post them here?
  2. Hi Loren, Some tsbs only load the first page. I tried to look at Cayenne tsb 22/07 4438 on troubleshooting the tire monitor system. I can only view the first page of thirteen. I tried multiple times and at different times during the day, both downloading directly to laptop or simply opening it up straight from site and it's always the same thing. Should I just keep trying or is this all we can get? Thanks
  3. Cloudsurfer, What ever became of this?
  4. RFM, If the sensor has no contact with the coolant how does it know what the level is?
  5. Loren, Is there anything in actual values or elsewhere that would give a clue that there's an issue with the MAF in a case like this or do you just have to roll the dice after replacing a brake switch? Thanks
  6. That's why I was recking my brain, thanks. One more dumb question: how do you PM?
  7. Loren, I found this post you made a few years ago: More than two meanings for the temp light... Covers all Carrera (996), GT3, TT / GT2 and Boxster (986) cars Here is the long explanation from the service manual on the flashing coolant light. "Four functions of the coolant warning light: 1. Engine coolant level too low -- light flashes slowly (0.5 Hz) 2. Engine compartment temperature too high -- light flashes slowly (0.5 Hz) (engine compartment blower might be faulty) 3. Engine coolant temperature too high -- light is lit; pointer on the right 4. Temperature sensor at water outlet faulty -- light flashes rapidly (1 Hz) ; pointer on the right Note: The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously." Can you give the exact reference for this? I've looked in the workshop and owners manuals and can't find it anywhere. It's driving me crazy. Thanks
