Schmides
Everything posted by Schmides
  1. Much appreciated Don. I'll look into this! Thanks.
  2. Bahhhh! This could be painful. Thanks for all your help Loren...much appreciated.
  3. Thanks Loren, Are there other part numbers that are compatible for my vehicle or do I need to find the exact match of #955-645-901-04. I've seen ones listed that state they are for an 04 Cayenne S with part number 997.645.334.33. Thanks again.
  4. Loren, do you know all the model numbers that would work as a replacement for 7L5.035.456B? Thanks in advance.
  5. I need to replace the faulty amp in my 2004 Cayenne S (headunit is CDR23, not a PCM). The model # on my amp is 7L5.035.456B. The dealership wants $1600CDN for a new one but I've seen a couple of used amps with model # 7L5.035.456D for much less online. Does anyone know if the .456D could be used as a replacement for my .456B? Thanks
  6. My 2004 Cayenne S is clunking on downshift from 5th to 4th. Dealership (South Centre Fine Cars in Calgary, AB) said I need a new valve body and listed a fault code of 1192 on my quote. What exactly is the 1192 fault code? Also, they quoted $1612 for the valve body part alone...can get it online at porscheoemparts.com for $842+shipping. Does anyone know if I was to get the part and have a private mechanic install if I need to have any type of electronic resetting that can only be done by a dealership? Thanks.
