bcrown
    Chicago, IL
bcrown's Achievements
  1. Thanks Maurice.
  2. There seems to be a couple of relays mounted inside the trunk on the passenger side wheel well. The cover does not want to open up. Is there any trick to removing the cover to access the relays? According to one manual I saw, it seems to be a pin inside the rivet but I can not figure out how to remove it.
  3. I have a 1995 993. It is the first Porsche I have owned and although the brakes work, they seem extremely stiff in the pedal. The pressure does not seem to change when the car is off or after it has been running. The car is supposed to have a brake booster and I am looking for someone with experience with this model to help me either find the problem or convince me that the brakes should be as firm as a car with power brakes when the engine gets turned off. Our there any easy steps or items to look for which would help me determine if the brake booster is actually working (or how to access it)? From what I gather, there should be some vacuum hoses to check as well as possibly a relay. Any help to point me in the right direction would be appreciated. Thanks
