FJCOURTS
Everything posted by FJCOURTS
  1. I'll try that. The radio screen works but no sound. Thanks
  2. Left the radar detector on and drained my battery. While jumping it in a rainstorm I hooked up the cables backwards. Everything recovered except the audio. No fuse problems. Any suggestions? Thanks
  3. Just got in 15mm Eibach spacers for my '04 C2. Purchased OEM 19" C2S wheels taken off a 2006 C2S. Fit great in back but are a little tucked in on the fronts (about 12mm). Loved the wheels so I ordered 15mm Eibach spacers. Followed their catalogue exactly and I got exactly what I ordered. The problem: The longer knurled bolts go inside to outside from the wheel support to the wheel with the spacer in the middle and require a wheel nut. My wheel studs goes outside to inside. No wheel nut. Do I need to order wheel nuts or did I just order the wrong thing? Should I order longer wheel studs? Thanks for your advice.
  4. I have put about 8K on my 2004 C2 since I installed sport H&R springs. Don't track the car. Results: Lowered about 1.5 inches (Way more aggressive looking) Handling in corners much tighter (Feels more planted and much closer to my Boxster which is a good thing) I think that the change has increased the cars tendency to oversteer. Takes some getting use to. Lowering causes you to drag on driveway dips and big speed bumps. Exercise caution! I have never felt the springs bottom out but the ride is much firmer. Good for sport driving but less comfortable on trips. I like the H&Rs but if I decide to track the car in the future I will upgrade the whole suspension.
  5. Loren, '04 C2 with 8K miles. Warm Idle pressure = "3" Thanks Frank
  6. Just came back from a ride and my oil pressure light comes on at idle. Manual and electronic oil levels say that there is adequate oil. Do I have a serious problem? Thanks
