Ale_72
Everything posted by Ale_72
  1. Cannot tell you much more than this (various copy/paste). I hope this is what you were looking for. Suspension struts (front axle) The spring strut consists of a double-tube gas-filled shock absorber and a conical spring which in turn is adapted to the different vehicle variants. PASM chassis Spring rate: 33 N/mm Sports chassis (-20 mm) Spring rate: 36 N/mm The springs have a colour coding which indicates the spring tolerance and/or the chassis version. Suspension strut (rear axle) The suspension strut consists of a single-tube gas-filled shock absorber and a coil spring which in turn is adapted to the different vehicle variants. PASM chassis Spring rate: 56 N/mm Sports chassis (-20 mm), spring rate: progressive 60/90 N/mm The springs have a colour coding which indicates the spring tolerance and/or the chassis version. A single-tube aluminium shock absorber is fitted in order to reduce weight. The main way in which tyre comfort has been improved is through the use of new support bearings with optimised shock absorption characteristics. In accordance to the versions, the support bearings (three variants) and the lower spring retainer are manufactured in different versions. Stabiliser The stabilisers’ setup in diameter and strength is designed to match the vehicle’s weight and driving dynamics. PASM chassis Tube 19.6 x 2.6 mm Sports chassis (-20 mm) Tube 19.6 x 2.6 mm The relocation of the stabiliser attachment points from the suspension strut to the wheel carrier has increased the transmission ratio of the stabiliser. The stabiliser responds more directly as a result, which more effectively reduces the tendency of the vehicle to tilt when cornering. Sportiness and PASM The chassis approximates the sportiness of the sports chassis when regulative interventions are made with active PASM Mechanical rear differential lock Only available with the sport chassis option.
  2. I called yesterday to book a dyno test my car in an "official" center (not linked to any chiptuner) but they have no available slot until Sept.
  3. I am a beginner as well, so feel free to correct me if I am wrong. From outside, if it's a manual transmission C2S you can see it from the middle radiator in the front. In the engine bay it's easy. The carbon airbox is easy to be identified. From inside, by the grin of the driver.
  4. From my (poor) experience, since I am on my first 911, and considering that I do not know which specs are standard in US. I'd look for a car with: Must have Manual transmission Full leather interior PSE - sport exhaust Recommended Powerkit Sport seats LSD All other stuff are, for me, simply nice to have. If you can afford the turbo, go for that!
  5. Better not to say to loud that when I found the car I had no clue of what "X51" was. I've chosen this just because, compared to other I had seen with similar specs, mileage and price, it had a nicer carbon air-filter box :lol:
  6. In almost one year I made a few changes to my car :thumbup: Text is in Italian, but pics should be "self-explanatory" http://sites.google.com/site/911carrera997s/enhancements A few pics (in the sub-albums) http://sites.google.com/site/911carrera997s/fotografie
  7. Tanks again to all of you. I tried with the 45 deg but it does not help... :(
  8. Wondering why I just got only now the email informing me that I have answers... Anyway... Unfortunately since I'm living in a condo there is nothing I can do with ramps. The only way I found to get into my garage without cracking noises is backing. In this way it works!
  9. hi, anybody have a few underside pictures of 997.1 with protection panels mounted? My garage ramp is quite steep, and I am trying to understand/have a clear picture of how the car is done "from below" :-) Thanks in advance for your help. Ciao Ale
  10. A couple of words about me. 38yo, from Italy, now living in Switzerland. My brand new/old car :o 997.1 C2S - 2007 - 25.000km (~15.000 miles) Specs/options 407 19 inch SportDesign wheel 425 Rear wiper :mad: 567 Windscreen with grey top tint 666 Telephone module 670 Navigation module for PCM 998 Leather interior in natural leather P12 Automatically dimming interior and exterior mirrors with integrated rain sensor P17 Sports suspension (- 20 mm) incl. rear axle-differential lock :D X51 Power Kit Carrera S :D :D :D :D XCZ Sport shifter :D XRP Wheel spacers, 5mm A few pics (just taken while driving back from the supermarket and my girlfriend was not overexcited of my idea of taking pics :P)
