pb84
Everything posted by pb84
  1. I need to replace my TPMS sensors. I own a: 2008 Boxster S U.S. spec vin WP0CB29848U730073 Which part do I need? 997 606 021 00 - or - 997 606 021 01 Please confirm that for the U.S. applications, the sensor functions at 433Mhz. Many thanks! Pat
  2. Loren - Thanks! Suncoast had the part on sale for $64.88. I understand there are two caps to remove along inner door sill to access two 5mm allen bolts (loosen a few turns only) then carefully pull up sill to release a single push plug anchor. Unplug electrical connector, switch can then be removed from bottom of sill - held in place by two screws. Thanks again!
  3. Can anyone tell me what the part number is for the front & rear hood/trunk switch located on driver's side door sill. My front switch cover broke off. 2008 Boxster S
