soan
Everything posted by soan
  1. i had change the fuel pump and regulator but problem still existed. how bout high pressure pump?
  2. -Cayman S 987 -2008year
  3. HARD TO START FOR FEW SECOND !! FAULT CODE - P1023, Fuel high pressure too low during starting. - P1026, Fuel high pressure implausible need to check which part, izit fuel pump problem? or......
  4. everytime i fuel up full tank, my car hard to start.Must start 2-3 times. it happen is only full tank, if i fuel up half tank then should be ok. Anyone can let me know how to fix it? thanks....
  5. ok, i will try it. thanks alot
  6. anyone can let me know how to fix? when i replace the battery ,i forgot to turn off the ignition key.After i replaced i try to start but engine no crank no sound no nth. help
