kp2011
Everything posted by kp2011
  1. Hi guys, i have found a problem with the cayenne (2004 3.2 v6)...over the last couple of mths, when starting it from cold, it seems to misfife slightly and run lumpy for the first 2 mins or so...once warm its ok... also i was checking the oil level yesterday and i noticed which seemed to be a taping sound from the engine? now the car has done 80,000 miles, has full psh....i have replaced the spark plugs recently, full service and all coil packs changed too..... any ideas what could be the problem? or are there any common things to go on them?? thank you
  2. Hi Guys, only just found this site after 5 years of owning porsches! i must be mad. so much info on here,i could have saved loads by not going to the stealers! Basically i developed a fault with my sunroof. i openened it the other day, whet to close it but it just keeps re-opening again? no matter where i turn the sunroof knob to, it does the same thing, closes then re-opens! i had a look in the manual and used the key in the console to close it manually but want to fix it. any ideas? thank you ...p.s also developed a fault with my n/s/f (rhd model) window...i can operate it perfectly from the drivers side, but it does not work from the passengers side?? ive replaceed the switch (which did not work) and all connectors behind the panel are in tact...
