Viperboss7
Everything posted by Viperboss7
  1. Wow, even the diagram is hard to follow. The first screw it shows is the one INSIDE the fascia. U have to remove all the torx screws under and the fender well screw to get at that. Then, it show a tab being pushed out on the front corner??? How do u get to a tab that is not visible? is the fascia supposed to rotate outward after the underneath screws are removed? Also it does not show fog lights being removed or even fogs in the fascia. Any tips on those points is much appreciated. Thx jk
  2. How are the fog lights removed?? Access is very limited. There is no front trombone to remove and the fascia is locked to the bumper in front and after removing the torx screws under the fascia I can pull it down a little to see the fog light backing but I cannot reach it. The only thing I see is a small hole in the fascia that allows a screwdriver to pass and adjust the beam position of the fog lamp. My main manual has good info on headlight removal etc but nothing on the fogs.
  3. Woops I could NOT find any info on fog light removal. I am not a mechanic but I was able to replace all the rear struts on the tailgate using posts from here! People here know more than my dealer....
  4. I looked to see if fog lights needed removal first. I could find a single word in my manual on fog light or even fog light bulb removal. I did see the adjustment screw for the fog light but i did not see how to remove it. Thx so much for the diagram!!
  5. I want to install a Bull Bar on my 2004 Cayenne Turbo. Have removed all torx screws under the fascia and the philips screws in wheel well but fasica still in there tight. Saw a thread on the steel plate install and they spoke of a bolt in the back holding the fascia in but I see no other accessible screws or bolts to remove. Any help pics or other would be appreciated!!!
