Atlas_Croc
Everything posted by Atlas_Croc
  1. Spoke to my dealers parts department, but they were not overly helpful,....they simply quoted the .88Z code but come to find out this is just the silver version and not the factory black painted version. Manged to find a copy of PET for the 991 but again there is only the 991.362.161.32.88Z part number listed (silver). Looking at some of the other wheel part numbers (ones that can be painted black also) and there are no part numbers for these either except for silver. I'll probably have to find a pretty savy dealer parts guy that may have come across this before, but for now knowing how to order a replacement factory black painted wheel seems to elude most out there. :(
  2. More info,....part number could also be 991.362.161.32.88Z That is the part number from the VIN info,....but I'm not sure if the .88Z part is the color code, from Porsche's description it means "bright chrome finish",...which it is certainly not as it is gloss black. Thanks again,....
  3. Hello - May have to replace a front 991 sport design wheel (damaged/cracked), I believe p/n is 991.362.161.32. The hard part is it is a factory Exclusive black painted wheel. How do I go about ordering this? Is there a different part number of suffix?....or color code for black? Thanks!
  4. Need p/n for triangular exhaust gasket that is between the output of the cat conv. to the primary center muffler. Thanks...
  5. Looking for part number for #4 on the diagram, drivers side side panel. Thanks!
  6. Need p/n for 2011 C4S drivers side underbelly panel / splash shield. Usually listed under front structual comp, splash shields. Thanks!!
  7. Hi all, looking for what is in an older version of PET (around 2005), P/N 996.552.571.00, color code 01C, satin black. This is for a 997.2 C4S, but as you can see it seems to harken back to the 996 days. This is the part number that is stamped on the piece and is listed in the older version of PET. It seems to have dropped off the face of the earth, hard to find. It is a protective sleeve for the upper fold down rear seat. One on each side of the seat where it pivots on a bar to fold down. It presses in the seat and protects the leather portion of it. Thanks!
