s.a.haynes
Everything posted by s.a.haynes
  1. I have had my 1999 Boxster for about a year now. When I first purchased the car is was getting OBD codes that eventually people on this group helped diagnose as a faulty MAF sensor. Since the replacement, the MIL has not come on. A beer to everyone for their help :beer:! The car was put away for the winter shortly after the replacement, so I really didn't notice the next problem until this spring. I have been having an issue with cold starts. The problem only seems to manifest itself if the car has been garaged overnight. It does not happen if the car is left in the hot sun during the day. The first time I attempt to start the car in the morning, it will cough and sputter and then stall out. Usually (but not always) the second time I turn the key, it will start normally. However, on some morning it will take me using the gas peddle to get it started, which usually causes the car to backfire and make rather nasty noises. In all cases once the car has been running for about 30seconds, all is fine and the car will run perfectly the entire day no matter how many times I stop and restart the car (even leaving outside at work for 8 hours). My Porsche tech wants to replace the engine coolant sensor, but even he claims that is "just a guess". Being that "just guessing" can get quite expensive on a Boxster, any other suggestions would be appreciated. Knowledge is power. Thanks. Sean
  2. The full data is: Calculated LOAD 2.3% Engine Coolant Temp 204degF STFT Bank 1 -10.1% LTFT Bank 1 -13.2% STFT Bank 2 -9.3% LTFT Bank 2 -14.0% Engine RPM 800 RPM Vehicle Speed 0 Hope this helps.
  3. I have 1999 Boxster that I have recently purchased from the original owner. It currently has 51K+ miles. Prior to selling me the vehicle the owner had the 45K service performed on the vehicle (at 50K miles). Soon after the service the CEL came on. He returned it to the shop that did the service and they said "bad gas," and turned the light off. I then got the car. A month or so after getting the car, I started having issues with the engine, especially on cold starts. The engine would "hesitate" when I applied the gas. Eventually the CEL came on again. I brought it into a shop that has a Porsche specialist and they said that they were receiving a "Throttle Body Potentiometer Fault" code. They calibrated the throttle body, reset the CEL and sent me on my way. After about a week of driving, the CEL came on again. They said that it was the same code and recommended that the throttle body be replaced. $1200 later I have new throttle body and no more hesitation (you would think you could by a rebuild kit for this that would be significantly cheaper... But that's a different story). The car is now running fine. However, I am having the problem that the CEL will come on after running the car for a while. I took it back to the shop and they told me that I was getting a O2 sensor fault. They reset the code and sent me on way again. They told me to contact them if the light came back on again. Being that I was getting a little wary about maybe being duped, I purchased a CANOBDII code reader. When the light came back on I plugged in and read that I was getting a P1123 and P1125 fault. Both of which indicate an O2 sensor out-of-range error. Looking at the FF data indicated that the car was apply a -14.5 adjustment to the fuel trim indicating that the car is running rich. The interesting thing is that this is only happening when the car is at idle (800 RPM). The mechanic also told me this answer (which makes me think they are not pulling my chain). The next question is how do we fix this? The shop mechanic mentioned the EVAP canister valve opening at idle. I was wondering if it could have something to do with the replacement throttle body. Any help would be appreciated. Sean
