smartrepair
Everything posted by smartrepair
  1. How much have you paid for the DME reprograming? Can you recommend any companies? Kare
  2. Thanks - I am in Madrid. Do you have the address/contact details for Balta? Hi. What kind of dent do you have? I know one guy who might know one dent guy. His cell phone is 660-423 578. He is based in Las Rozas. Regards y saludos Kare
  3. Just read an artical in a UK Porsche magazine ( I left it on my boat so I can't say which one specifically ) about a business in UK called autofarm. They rebuild Boxster and 996 motors and one of the comments was how few special tools are required. This company even bores outs and replaces cracked cylinders in a process they are pioneering. They are too far away for me but maybe you might be able to get parts from them? They also offer enlarged bore cylinders and pistons for boxster motors. Also I read another article that said the 3.4 intake manifolds are too tall to fit into the boxster. The person doing the retro fit ended up lowering the whole engine/tranny assy mounts to accomodate the manifolds. This worked OK but gave him reduced ground clearance in a vulnerable spot. Eric I found the Autofarm web page some time ago. Looks like the parts are not a problem, there are quite a few companies who can sell them. But as I´m located in Tenerife, and the local machine shops don´t have the specifications to check the crankshaft, valve clearances etc. etc. Does anybody has these values???? Here a rebuilt engine from Porsche costs eur 13000 (about $ 16250) so I´m looking for alternative routes. The 3.4 installation is not a problem either, I downloaded the instructions from this site, and I think it wont´t be too complicated.
  4. Has anybody any experience in doing a complete overhaul to a 3.4 996 (1998) engine? Is it a thing a "normal" guy can do, without too much experience on it? I have the Porsche workshop manual, but I´m wondering is it so easy in the end. I bought a used engine, without guarantee, and it has about 90.000 miles on it. I´m going to install it in my 98 boxter... The problem is the Porsche manual I have does not include the crankshaft, rod bearing etc. specs, only torque values. Thanks Kare, Spain
  5. Ditto that. Loren puts together (along with the 'family' here) some of the most useful info for us. Did it last night!
  6. I found the TSBs on "Online Docs menu", but it´s not possible to open them. Is there any way to read them, or are they copyright protected, or....? Regards Kare
  7. My 98 Boxter is 98 US model, so it will have the driveblock. How much are you paying for the reprogramming? Of course I could send the DME to the States...
  8. My 3.4 conversion project goes very slowly forward, I already have the engine block. Still searching for the intake manifold. Does the 996 standard ECU (from year 1999) fit to my 1998 2.5 manual Boxter? In Spain I haven´t found anybody to reprogram the ECU, and found this unit which is for sale... Thanks Kare
  9. Hi My fuel gauge is not showing the correct amount (when I fill the tank, the gauge shows only 3/4 full). Are the any process to correct this? After the swap was made the gauge worked well, don´t know what happened.... Kare
  10. Hi everybody I haven´t solved yet the oil burning problem. My 98 2.5 manual Boxter still smokes, although I changed the oil separator. We measured the compression in all cylinders and 5 of them had around 145-150psi, and cylinder 4 had only 135. Underneath there are some oil coming out around the cylinderhead at cylinder 4 (between the head and valve cover. Also there was oil at the exhaust collector at cyl. 4). The spark plug was a bit oily as well. The rest of the cylinders look fine. What can it be? A valve related problem? Here in the Canary Islands nobody knows (!) about the leak-down test suggested in this forum, so I cannot do it. The local Porsche dealership is moving into another installations and are not attending clients for the next two months.... When I start the car, a lot of blue smoke comes out. When I go to drive to the highway, the smoke disappears. But after the cars stands still for some hours the smoke comes back... Thnaks Kare, Spain
  11. I bought the engine block. Now found cheap Boxter S (3.2) intake. Does it fit???? The engine block is without any intake, throttlebody etc. Plese advise quickly, I have to make desicions.......... kare
  12. Hi everybody I´ve been trying to find an 3.4 engine. Now I found pretty cheap one, but it´s not complete, there´s no air intake/throttlebody assembly. I suppose I cannot use even a part of my 1998 Boxter 2.5 assembly? I was looking at the other posts and the 3.4 looks different... as I´ve undestood the exhaust side will fit, although not ideal. What about the cooling system of the engine: as it´s bigger souns logical that additional cooling is required. How have you solved that? What experience do you have with the swap in general? Any problems? And the positive experiences??? Thanks Kare, Spaijn
  13. UUps, the link is not direct, you have to go to the "refinements" to see the two RUF boxters. Kare
  14. HI guys Here´s the RUF´s web page. Yes, it´s the german one, but there are some articles where you can get some ideas of the prices. http://www.ruf-automobile.de/english/index1.htm Regards Kare
  15. You are welcome to come over..to Spain! The food and wine are excellent.... and there are some interesting Porsches around! So the shifter I have to take out the whole assemply (with tower) to cut and shape it? Other thing: there is a bit of slack on the shifter. Are there any specific parts to change, or is it just adjustement problem? The slack is in both shift and selection direction. When I accelerate a lot, shifting from 1st to 2 nd the gear doesn´t enter perfectly (the clutch makes a noise). It only happens when there is much revolutions (about 5000) and between 1st and 2nd. Kare
  16. Thanks, I´m going to have a try.... BTW I did a search, but couldn´t find those topics you posted. Incorrect keywords...
  17. Hi. What is the difference between the short shifter kits and the original stick? The travel is shorter, but how is it acheived? I was wondering to cut the original shifter just 1" shorter (I don´t like the looks of the original one, it looks too long). Is it a crazy idea? I did a similar thing many years ago for my Pontiac Fiero... Thanks Kare
  18. I did nothing with il pressure gauge - waiting for the 3.4 swap.
  19. Finally did the swap: very easy and a positive surprise, the outside temperature was working as well (no need to visit the Porsche dealer). The cluster I bought was from a tiptronic (mine is manual), so I have the 4th geat flashing continuously. But everything else works fine. I simply cut off some plastic in my original trim going around the cluster to fit the two additional gauges. The next step is 3.4 conversion.....
  20. Well, at least I would have the Guiness Record of the fastest vehicle on planet going...backwards!
  21. Hi Trying to find a good 3.4 engine for my swap project. I found a nicely priced one, with 6-speed transmission included, and 996 computer, year 2000. Can I also fit the transmission in my 1998 standard 2.5 Boxter? Does the computer work with the rest of the components of my car? On other posts the original computer is reprogrammed and the original wiring harness is used. Many thanks Kare
  22. Hi I´m on a leather repair business. The SEM Sure Coat is the best dye you can buy. Just clean the leather well before applying the paint (with leather cleaning product, or acetone). This is very important. Kare, Spain
  23. Took the oil "sample". Everything looks normal, the oil is like new (it has about 3500 miles on it now). When I start the engine, it takes about 3 minutes until the BLUE SMOKE comes out. There´s a lot of smoke until the engine reaches the normal operating temperature, then much less (but more than normal). The funny thing is there´s not the normal/typical initial smoke coming out at starting. What you think?
  24. I agree my description was not enough. Sorry for that! This forum has solved me so many problems before (without asking a question, just seraching the previous posts). Many thanks for all members! There is more and more white smoke getting out. I checked the oil separator, and at least I could not locate any oil leaks and looks like the installation is OK. One thing: the mechanic used the old top tube going from the separator to the air intake. He said that he heated the tube a bit and it slipped into it´s place. There are no visible dents or obstuctions in this tube, so I don´t think this is the cause, but..? The engine burns a lot of oil ( 1 liter per 1000 kilometers), and I noticed that the coolant level has gone down as well. I have not noticed that the engine has overheated. Are symptons for burnt head gasket, or ..? Many thanks Kare
  25. Uh, my problems with my 98 Boxter 2.5 won´t end... The original problem was a huge amount of white smoke coming out, not exactly after the start, but it comes after few minutes. I changed the oil separator, as it was the first suspect, but it didn´t solve the problem. What can it be? I´ve had also the CEL light on, the first time I took the codes out it gave me the following: 0410, 1121, 1147. I cleared them and drove the car for a while. The CEL light was on again, now showing 0410, 1147, 1411. I understand nothing as many codes are not Porsche or other standard specifioc at all... The engine burns a lot of oil. But as said it cannot be the oil separator, so what can I do/ expect???? Thanks Kare, Spain Another problem: sometimes the engine begins to knock (here in Spain we have 95 oct fuel, my car is US model). It goes away, if I go to highway and drive a while. I suppose there is a problem with vario-cam. What is the part I have to check????
