kevster996
    Brighton, UK
    1974 914 2.0
    1991 944 S2 cabrio
kevster996's Achievements
  1. 986 install (1999 2.5) Firstly thanks very much guys for all the help above, me and a friend managed to do the job above on my 986 in about 30 mins (dealer said they block out 1 1/2 hours). - found a deflector on ebay (with the levers attached) - £50 - found the mesh grilles on ebay - £50 - bought a fitting kit from the dealer - £16 (6 rivets, 3 brackets) Prized off the trim (3) by hand (tight but no broken clips), riveted the centre bracket onto the padding. Found 1 hole each side on the rollbar hoops pre-drilled so riveted the brackets on using just one rivet per bracket (tried drilling a 2nd hole on each but gave up as realised I may be there some time!). When fitting the L & R brackets we fitted the centre trim and sat the deflector in place so were able to line everything up just as a check. Popped the trim back on and pretty much job done!
