bigfoot007
Everything posted by bigfoot007
  1. I can already switch between the two on the digital, but I must have the analogue in MPH as well.
  2. Hi, I am moving as the subject says. Does any one have any experience of converting the head lights to right hand drive from left hand drive (spare lights anyone!), and the speedo, thinking of getting a new foil to show both the MPH & KPH. Any advice will be more than welcome. Car is 2003 turbo
  3. I have just spent most of today trying to get the trailer hitch (MY03 cayenne turbo, it is fitted with the auto out/in system) to work, e.g. to extended and retract. There no error codes on the Durametric. Checked all fuses = OK removed module = nightmare to get those panels off!, just to get at the plugs Went through the Diagnostics from Porsche, but they are a little confusing, but found no shorts etc. Looked at the wiring diagram and decided to see if the hitch would move when I bypassed all the electronics, surprise, it did all the way out, problem is now I cant get it to go back in again, not sure if reversing the polarity to the motor would be too good!! Has anyone had to go through the process of fixing their OEM system, and has a fool proof method of doing it?
  4. P0016 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A )
  5. I live just down the road from you, interested as to where you had this done.
  6. Thanks for the link, but by the time I pay for the P&P + tax, it works out dearer than her in Switzerland! Like the idea of using a bit of string.
  7. So next question is: Has anyone done this change of sensor? if so how easy is it. Looking at the service manual its shows to be fairly straight forward.
  8. Thanks Loren for clearing that up, others say left is the oil cap side
  9. Left side looking from the front I assume.
  10. I have just got a P0140 error code = Oxygen Sensor After TWC, Bank 1 - Open Circuit, so I will have to get a new sensor, but I need to know which side of the car is bank 1. I know the part number is 955 606 136 01, but I find two types of sensors with different sockets. http://www.123pieces...0606%20136%2001 or http://www.123pieces...ms_per_page=10 So does anyone know which one to use? MY03 Turbo
  11. What was the original language of this guide?
  12. The problem is that the drivers switch wont block the rear window switches in the rear doors, Is there a relay or something that controls this that I can check? I know that there is the usual mechanical lock to prevent the children opening the door from inside, this I have already done.
  13. I have just got a 2003 Turbo, very clean and full service history. One problem though, the switch on the drivers side door to control the child safety in the rear (doors & windows), doesn't seem to work, the light on the switch goes on only when it is depressed, then nothing. Holding the switch down, you can still operate the rear windows & locking. Has anyone else had this problem?
