Flanagan
Everything posted by Flanagan
  1. Thanks Loren! So it's different from the 996 which uses position 10, as per this drawing that I got from one of your posts. Not even at the local Porsche Center in Milan were they able to give me an answer!! Many thanks again and keep up the great work you're doing! Regards from Italy Here's the drawing I did not attach before... Support 2 996.PDF
  2. Hi Loren!!!!! As a first thing : thanks for your precious attention to my question; as a second one, sorry for the delay in answering! Finally: my 997 GT2 is a 2009 version, produced in august-september 2008 and delivered new end sept. 2008. Chassis wpozzz...9z....776116. I live in Italy, so it's a RoW car. Had this problem of relais falling down probably because after a recurring P2629 error , I had used contact cleaner on all the relay contacts. Somewhere I read that P2629 error, (O2 sensor pumping current trim circuit/open bank 2 sensor 1), could occur for a Faulty secondary air Pump relay. Changed both lambdas and relay but still P2629. Thanks again and compliments for your detailed answer to the most incredible questions!!!
  3. anybody has a drawing with the scheme of relay support assignment? I got it for the 996 turbo, but not for the 997 GT2... Thanks a lot.
