Guetstar
    France
    Other
    cayenne turbo-03
  • Future cars
    cayenne S-08
Guetstar's Achievements
  1. Hi at all! i no have compression at cylinder n°3, i'm checking exhaust valve, but i would like to know if someone have a workshop manual, for valve timing? I really need your help for that thank you
  2. yes i've install oem coil and plug.. yesterday i've found oil on admission circuit on bank 2..
  3. i've install ngk plug and beru coil.. wednesday i've change injector 3 to the 1, and now appear misfire cylinder 1, 3 and 7, maybe is fuel pump or battery, battery is little tired, and fuel pump no change!
  4. :cursing: :eek: i've make a video car smoke white but more than 1 week engine no work and when i've take video engine work 5min..
  5. but engine compression is good at all cylinder..? i can have good compression and valve or lifter problems?
  6. Thank you Loren for your reply i have already change ignition coils, spark plug, check injector, check compression engine, check wiring,.
  7. hi thank you very much for your reply i have fault code p0300, p0303 and i have sometimes p012f and told me misfire detected cylinder 3 code error p012f..
  8. hello at all! someone have a rapair workshop manual of cayenne turbo 2003???
  9. hi i'va again misfire dtected on cyl n°3 only now, i've change the 8 spark and coil.. when i test with durametric on actual value i've misfire only on cyl3 and low rpm, when i put rpm at 3500/4000 i no have misfire!!! someone have an idea?
  10. ok.. i've change all the spark plug and all is ok now!!! strange obd code error!!
  11. I deposit the vehicle to the workshop .. verdict tomorrow ..
  12. hi, thanl you for your reply, what do you mean by "timing"? thnk you
  13. Thank you for your fast reply, i will check it tomorow! :cheers:
