Guetstar
Everything posted by Guetstar
  1. Hi at all! i no have compression at cylinder n°3, i'm checking exhaust valve, but i would like to know if someone have a workshop manual, for valve timing? I really need your help for that thank you
  2. yes i've install oem coil and plug.. yesterday i've found oil on admission circuit on bank 2..
  3. i've install ngk plug and beru coil.. wednesday i've change injector 3 to the 1, and now appear misfire cylinder 1, 3 and 7, maybe is fuel pump or battery, battery is little tired, and fuel pump no change!
  4. :cursing: :eek: i've make a video car smoke white but more than 1 week engine no work and when i've take video engine work 5min..
  5. but engine compression is good at all cylinder..? i can have good compression and valve or lifter problems?
  6. Thank you Loren for your reply i have already change ignition coils, spark plug, check injector, check compression engine, check wiring,.
  7. hi thank you very much for your reply i have fault code p0300, p0303 and i have sometimes p012f and told me misfire detected cylinder 3 code error p012f..
  8. hello at all! someone have a rapair workshop manual of cayenne turbo 2003???
  9. hi i'va again misfire dtected on cyl n°3 only now, i've change the 8 spark and coil.. when i test with durametric on actual value i've misfire only on cyl3 and low rpm, when i put rpm at 3500/4000 i no have misfire!!! someone have an idea?
  10. ok.. i've change all the spark plug and all is ok now!!! strange obd code error!!
  11. I deposit the vehicle to the workshop .. verdict tomorrow ..
  12. hi, thanl you for your reply, what do you mean by "timing"? thnk you
  13. Thank you for your fast reply, i will check it tomorow! :cheers:
  14. 19 and 20 are the knock sensors. They are under the manifold. Thank you!!
  15. Hi, some one can tell mr wich is the number 19 and 20 please? thank you
  16. Hello at all!! I am Alex from France, i have a Cayenne Turbo 2003 with 68,750miles (110.000kms).. I have a problem with cylinder 3 & 7, when i have do check control with durametric, the result is: Bosch Digital Motor Electronics 7.1.1 Codes d'erreur actuels P0300: Some missfire detected - Value below lower limit value, test conditions are not-completed, fault is currently active and causing a DTC light P0303: Missfire detected cyl. 3 - Value below lower limit value, test conditions are not-completed, fault is currently active and causing a DTC light P0307: Missfire detected cyl. 7 - Value below lower limit value, test conditions are not-completed, fault is currently active and causing a DTC light When i run "short test" on all vehicle with durametric 6, i found same problems but with different ERROR CODE Bosch Digital Motor Electronics 7.1.1 Codes d'erreur actuels P2C01: Some missfire detected - Value below lower limit value, test conditions are not-completed, fault is currently active and causing a DTC light P2F01: Missfire detected cyl. 3 - Value below lower limit value, test conditions are not-completed, fault is currently active and causing a DTC light P3301: Missfire detected cyl. 7 - Value below lower limit value, test conditions are not-completed, fault is currently active and causing a DTC light I have never see in the past this error codes, i've found error code p3301 is: Bank 1, cam shaft position sensor, discharge opening (G300), interruption / short-circuit tp B+ but one thing i no understand, p3301 is error for cyl.7, but p3301 is bank 1, and the cyl.7 is in bank 2, tell me if i'm wrong.. I have already change ignition coil & spar plug I will need help Thanks U.S.A. Alex
