maxjamie
    02 996TT, 01 MB S600, 04 VW Treg, 01 MB CLK430 Cab, 06 Odyssey Touring
maxjamie's Achievements
  1. Hey Loren, you da man!!! I called the dealer and explained the problem, they seem to agree with your TSB problem and as "good will" , they will cover it under warranty (expired 2 mo ago). They seem to think it is safe to drive the 150 miles to have it dropped off. I hope they are right. Thanks for your advice!! Ted
  2. So far only happened twice, both in the morning (40-50 degrees) after driving 5-10 minutes. After shut down, 30 min or so later, no message. Pardon my ignorance, TSB?? (Technical ?? Bulletin?) If TSB, does it hurt to continue to drive without a visit to the dealer? My warranty has expired and the nearest dealer is 150 miles away. :( Thanks for the reply. Ted
  3. Hello you all porsche fanatics!! I have a Q on my 02 996TT with 23k , 6speed, upsolute, Evo intake, RUF exhaust. I recently changed the oil/filter myself and after 200 miles, I am getting "low oil pressure warning" message. The oil press gauge seems fine, car drives and sounds normal, oil level is good, nothing abnormal on visual inspection under the hood and under the car. Any thoughts??
