windy-i
    Seattle
    2007 Porsche Carrera 4S Cabriolet
windy-i's Achievements
  1. I recently installed an AIM Solo DL data logger in my 2007 C4S Cabriolet. The battery has gone dead several times while at the track and I would like to wire it so the car's battery will charge. As the Aim Solo is wired into the Can Bus directly, I would like to find out if there is a 12vdc ignition switched wire that goes into the ECU and which wire it is.
  2. I have a 07 C4S Cab with about 35k miles and attend about 10 to 15 DE events per year. The only suspension mod I've made is to add adjustable camber plates and set the camber to -2 degrees. I also use 18" wheels on the track with Nitto NT01 tires. As I want to use the car mainly on the street I've been talked out of any other mods. I met someone at the track who replaced their sway bars with stiffer ones and didn't like them even with the softest setting and went back to the stock ones. The major change I made was replacing the front brake rotors with floating ones, adding stainless steel brake lines, high temperature racing brake fluid and pagid yellow pads. The stopping distance reduction is phenomenal and I catch a lot of faster cars because I brake a lot later going into turns. The only problem I have with the floating rotors is the noise they make when driving on the street.
  3. change password
