IBEQUIP
Everything posted by IBEQUIP
  1. Ffeibiss, Did you add any reverse camera to your system ?.
  2. put the new battery Bosch S5585B few days ago but the PCM will not switch on too. Planning to send to Porsche Authorised dealer this week. any other advise ?.
  3. My 08 Cayenne Turbo's PCM switch on by itself while I stuck at traffic jam. Then, "Engine Off Operation only possible for short time" appear on the PCM eventhough my engine is running. after few minutes PCM turn off by itself. this cycle happen for few times. after that, it did not happen again eventhough i drove my cayenne for about 4 hours. Up to now, my PCM is still dead. Is this problem caused by weak battery ?. I also plug my durametric cable two days later and the green light is not on.
  4. My 08 Cayenne Turbo's PCM has different PCB from Bigbuzuki's. It did not want to switch on. Then, I remove it from my Cayenne and check the PCB. Unfortunately, my ST10F269-T6 chip is different from above. see below photos. Can anyone help to rectify this problem ?.
