treifeiss
Everything posted by treifeiss
  1. After trying multiple times I went back to a search and found I was missing a couple of important steps. Thank you Mike Focke. I have a model with the C3 fuse that you pull out to open the trunks. You need to move the door latch to the closed position (one click) then using the key, lock and unlock the door. The alarm will stop sounding then beep once or twice when you turn the key in the door. I pushed on the fronk release switch and BINGO! I am in. I think Porche made it so you have to have the key turn in the door so the "bad" guys can't get to your frunk without having the key. I've cut and pasted the instructions below, and also the website where I got the information. If you have any questions send me a message and I will help if I can. 2001 986 Boxster ...and from the Porsche TSB. "Should the front and rear hood releases become inoperative due to a disconnected or discharged battery, the following procedure will allow the hoods to be operated electrically under these conditions.· Open the left door.· Using an external battery, (I used a car jumper) connect the negative lead to the door stop.· Connect the positive lead to both sides of fuse "C3".· With the door open, move the door latch with a screwdriver into the closed position.· Using the key, lock and unlock the door.· The front and rear hood releases can now be operated. Here is the website of the instructions; https://sites.google.com/site/mikefocke2/whenyourbatteryisdead
  2. Help!!! I've tried everything listed here and I still can't get into my front trunk. I can't use the emergency cable because I can't get the front tire off because the tire lock is in...you guessed it, the front trunk. Any ideas?
