kbendon
Everything posted by kbendon
  1. Then why would the complete light work when plugged into the passenger side and vice versa the passenger side Headlight has the same effects (only high beam works ) when plugged into drivers side? make sense? sorry so many questions
  2. I have read through posts for weeks on this and have tried everything. Low beam still not working. I can hear the level motor but the light doesn't come on I have switched ballasts=same result I have switched d1s light = same result Have replaced with NEW d1s bulbs= same result I have replaced the harness behind the headlight=same result I have taken the whole unit out and plugged into the passenger side and the complete light worked I have check the low beam fuses=fine both turning lamps do not work but haven't changed bulbs yet What else could it be? Thanks for any help
