Jacky Hermes Yuen
Everything posted by Jacky Hermes Yuen
  1. The code went away but I was presented with these... P5D41 P2B41 Have anyone seem these codes b4? thanks
  2. ok, I will go to the shop and run the diagnostic again. I will probably report back tomorrow. I'll let you guys know...
  3. mmmm...i was just reading some other post regarding the oil change....The reason why I decided to write this was because I was told and HAVE just changed the oil. They said doing this might make the engine light go away. I guess its not the oil or filter thats throwing off the engine light... So the code came out and P0349 was the only code that popped out. The mechanic told me to change the camshaft sensor 996 606 106 02....but he told me it was the passenger side. But now I can confirm with him its the driver side. (i'm in canada) Sry to confuse you or anyone else reading this, I saw different fault codes(but similar) regarding the same thing and just wanted to make sure that I'm paying the mechanic to fix the RIGHT issue. thank you
  4. Hi Loren, I don't think its the *Ignition bar module* which you posted. By seeing the Fault code from Durametric, are you able to let me know which number on the engine diagram i need to change? thank you
  5. Hi Loren, The master mechanic told me that the sensor on the *Passenger Side* needs to be changed. Can you confirm if *Bank 2* is on the passenger side? But now I'm confused...since you mentioned ***Camshaft rotor (phase sender wheel) damaged.*** So is it the rotor or the sensor? I own a 04 cayenne turbo. thank you in advance.
