CapoGiro
Everything posted by CapoGiro
  1. Ok, new to the forum, but have read just about everything I could find on this topic. I have had my 2006 S since the day after Thanksgiving and noticed early on that the passenger carpet was wet. Driver side completely dry. Thought it was isolated to the area immediately under the passenger seat (more to come). After reading all the great posts available on the subject, i cleaned the leaves out from the drain areas and tested the drains to ensure they flowed freely. Everything is good -drains flow and the pan does not leak. At this point I thought that the issues was fixed by cleaning the drains. Reinstalled the carpet (after completely drying) and seat. Thought that I would wash the car before putting away for winter. As an aside, I was cautious about the amount of water I let run on the roof/clam shell since I was gun-shy. I did try to get the salt and dirt off of the undercarriage as well so I hosed the under side of the car pretty heavily. Well, as you guessed, I checked the carpet to find it wet again. Removed the seat again and this time ventured further towards the foot well area. Yes, wet padding up there as well. Does anybody have any additional ideas of where the water can be coming from? I saw a post somewhere stating that it could possibly be coming from the door if there was work done on it and a plastic sheet not sealed properly. I know that I can sit in the car with someone hosing the outside but I am trying to avoid the clean up process for a third time.
  2. Ok, new to the forum, but have read just about everything I could find on this topic. I have had my 2006 S since the day after Thanksgiving and noticed early on that the passenger carpet was wet. Driver side completely dry. Thought it was isolated to the area immediately under the passenger seat (more to come). After reading all the great posts available on the subject, i cleaned the leaves out from the drain areas and tested the drains to ensure they flowed freely. Everything is good -drains flow and the pan does not leak. At this point I thought that the issues was fixed by cleaning the drains. Reinstalled the carpet (after completely drying) and seat. Thought that I would wash the car before putting away for winter. As an aside, I was cautious about the amount of water I let run on the roof/clam shell since I was gun-shy. I did try to get the salt and dirt off of the undercarriage as well so I hosed the under side of the car pretty heavily. Well, as you guessed, I checked the carpet to find it wet again. Removed the seat again and this time ventured further towards the foot well area. Yes, wet padding up there as well. Does anybody have any additional ideas of where the water can be coming from? I saw a post somewhere stating that it could possibly be coming from the door if there was work done on it and a plastic sheet not sealed properly. I know that I can sit in the car with someone hosing the outside but I am trying to avoid the clean up process for a third time.
