Weird_Ed
Everything posted by Weird_Ed
  1. If you want your side markers to act as turn signals this is what you do:- Remove CD changer if fitted - remove front carpet pieces left and right- remove plastic cover around brake fluid tank to access wiring loom- remove slotted plastic cover under CD changer - pull back carpet on pass side to access wiring loom- unwrap wiring loom and look for gray-red 0.75 wire- follow wire until it splits into gy-rd 0.75 (parking light) and gy-rd 0.5 (side marker) (approx underneath xenon headlight leveling box)- cut thin gy-rd 0.5 wire, isolate end going to firewall- Find 0.75 black-green wire (turn signal) near end of cut gy-rd 0.5 wire, strip isolation and connect both wires. Solder and isolate.- Passenger side is now done- on driver side locate big white plug and find 2 gray-black wires coming out of the plug. One is 0.5 (side marker) and one is 0.75 (parking light)- cut thinner gy-bk 0.5 wire directly at the plug - find 0.75 black-white wire (turn signal) and strip isolation - connect gy-bk 0.5 to bk-wh 0.75 wire, solder and isolate- reassemble- Enjoy Euro turn signalsI first did not find the thin gray-red wire on the pass side and made the mistake of cutting the 0.75 gy-rd upstream of the split. I had to patch a wire in to fix the parking light but everything works great.Bonus effect: Now you see if your alarm is armed when you walk away sideways.
  2. Hi, I need to convert my side markers to turn signals but the wiring diagram I have (2001) does not fully match the wires in my trunk. Can someone please post a 2003 xenon headlight wiring diagram please. Much appreciated!
