Enchilada Jones
    south eastern USA
    '03 996 C4S
    '88 928 S4
597 profile views
Enchilada Jones's Achievements
  1. I have a 2003, 996, US model C4. The driver side headlights do not come on, The turn signal does not come on. The side marker does come on. The turn signal indicator blinks rapidly if I select a left turn. On the right side everything works as designed. I have removed the headlight and tested the connection socket where the light assembly slides in and connects the circuits. There are two ground wires there and both of them test as good by putting a test lamp between them (one ground at a time) and positive on the battery. Of the other pin locations in that connection socket there is only one pin that has 12 volts potential to ground when the light switch is in the on position. It doesn't matter if I have the high beam or low beam selected nor does the turn signal change where power is detected. I think, if I read the diagram correctly, that there should be at least two wires providing power to the light assembly. But perhaps that was supposed to be after the one wire fed power to the assembly. I haven't figured out how to understand the symbols indicating connectors and where they are in the car etc. Can anyone tell me what I should be finding as far as power to those pins and under which switch positions they would be 'hot'? The way the socket is oriented it is 2 rows of 6 pins one row over the other. Standing at the front facing the socket the grounds are top left and bottom right and the one pin that I have power to right now is second from left on the bottom row.
  2. I'm going to fly out and pick up a new-to-me 2003 911 C4S. I've never owned a 996 before so I'd like to download the owners manual for reading on the flight down to get familiar with the car. I want to learn where the fuses are...location/how the controls work, warning lights, etc. so the drive back will be a little less tedious and hopefully about enjoyment. I cant find a source for it on the internet. Does anyone know if it is available or something like it? Thanks
