Search the Community
Showing results for tags 'airbag fault 803a'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Hi all: I'm obviously new to this forum -- looks like some great technical discussion! Okay, I came across this site trying to address an issue I am experiencing with my new-to-me 2007 911 Turbo. Situation: Bought the car a couple months ago (45K miles) and it had full leather adaptive sport seats with heat/memory as well as deviated seat belts. I knew I wanted to change the seat belts throughout the car to standard black but didn't want to pay for brand new ones and was uncertain about re-webbed ones from Maxspeed, etc. So, I sourced used ones. Rear belts were from another forum member and had a clear history. Front belts were from LA Dismantlers, so presumably from a donor car Prior to replacing the belts, I acquired a set of of leather/alacanta insert adaptive sport seats with heat memory from the same forum member as the rear seat belts. The seats came from a 2009 TT. The seats were complete with buckles. I installed seats and belts after disconnecting the battery for 20+ minutes. All connectors appeared to be well seated. Upon reconnecting the battery and starting my car, I received a variety of faults but all cleared within <1 mile of driving and a restart. However, the airbag light remained illuminated. I since sold my deviated belts so cannot test a known good pair. I still have my original seats (sitting in my living room). Where I am at today: I used a Durametric Enthusiast to further investigate the airbag light and came up with 2 codes: 8039 - Driver's belt tensioner below lower limit 803A - Passenger's belt tensioner below lower limit I attempted to clear the codes but they continue to pop right back up. Airbag light remains illuminated. I looked under the seats to make sure the plugs are well seated and they appear so. I will completely unplug and plug back in this weekend just in case. I am pretty certain I properly re-inserted the tensioner plugs into the front belts but will need to pull panels off and recheck this weekend Questions I have: Are these codes likely emanating from the seat belts or under-seat wiring? Is it possible they are coming from the buckles? Is this the typical fault seen after the tensioners have been been used already? Since I received the belts from LA dismantlers, it is possible the tensioners are now DOA. While LA Dismantlers inspects the seat belts prior to sale, it isn't clear to me if they test the tensioners to still make sure they are good before reselling. I have seen online that you can test tensioners by measuring resistance across the terminals on the units using a standard multimeter. A steady 2-3 ohms is good, fluctuating lower or higher numbers means the tensioners are dead. Does this procedure work for Porsche units (the seatbelts will be unplugged/no power, of course)? Durametric has told me the unit will clear the code no problem as long as the issue that triggered the fault is fixed. I've read conflicting advice on other sites, saying that a dealer PIWIS reset is required. Which one is true? Is there a comprehensive list of Porsche 997 OBD2 airbag fault codes available? I'd like to scan through them to better understand how to isolate my 2 errors to the seatbelts, seats, or buckles. Next steps: I am going to ensure wiring for the seats and seat belt tensioners is fully seated. I'll double check grounds and other wiring nearby as well. I'll also try to test resistance within the tensioners as mentioned above. LA Dismantlers offered to send me another set of front belts, but I don't want to replace them just yet... I don't know for sure that the belts are bad....Wow, sorry for the long post but hopefully everything is crystal clear. Now I hope one of you smart folks can help me answer some of the questions I raised. TIA!
