Search the Community
Showing results for tags 'p1123 cel maf o2'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Drove home and CEL came on. Attached my Durametric. Error code is P1123. No other error codes. Car is stock with 20k miles. No recent known problems. I did have a non-start problem before: http://www.renntech.org/forums/topic/43615-changed-oil-installed-997-shifter-now-car-wont-start/ ...but after replacing the fuel filter, I haven't seen any symptoms in five months. Idle is at 680 RPM. Air Mass reading is 15-16 kg/h at idle and 50 kg/h at 2500RPM with no load. Oxygen sensing reading for cylinders 1-3 is 1.01 to 1.05 and for cylinders 4-6 s 0.99 to 1.02. O2 sensors read between 0.4V (lean) to 0.78v at idle and 2500RPM with no load. Due to wife and nagging woman problems, I won't have time to dig into the car until this weekend. Checking the EVAP canister purge valve is on the top of my "to do" list. So I do apologize for posting without doing as much due diligence as possible, but, again, time concerns. Some guidance up front could easily prevent me from unnecessarily replacing moderately expensive parts. Due to the lack of other CEL codes, the fact the car is running rich and I don't plan on driving it hard, and the code being a non-serious error, I cleared the error code and will drive it the rest of the week to see if the error retriggers. So, my initial questions for the masterminds here: In Durametric, what is "oxygen sensing reading"? My best guess is that it is the flow rate injector compensation, but if that is the case, the value was changing constantly. Does that 0 to 0.03 discrepancy noticed between cylinder banks provide any useful information to further diagnose the cause? The MAF sensor readings look within spec, and since the MAF affects both cylinder banks, it seems unlikely to be the culprit. But, the sensor is 14 years old, countered by it only having 20k miles. From what I have read, the MAF sensor seems to take the blame for a lot of P1123 issues. But that could be misdiagnosed, especially if the issue is not easily reproducible. The O2 sensor values seem right, but I'm basing that on other vehicles, and the car wasn't under load. Do those values tip off any red flags? Are there any other metrics I can pull from the Durametric that might reduce the number of potential areas to investigate? Thank you!
