I took my 1997 Boxster to have the brake discs changed out and when I went to pick it up I noticed that the odometer almost couldn't be read. It's very strange. It works, but, it almost looks like it's peeling with a spider-web type effect on the inside. Has anyone every heard of this? The car was parked outside 5 or 6 hours until I could pick it up and it was pretty hot out. Maybe the sun shining directly on it? I take it that I'll have to change out the whole cluster ??? You can see that there's no type of physical damage on the outside. I would imagine it's a mini LCD and it's permanently soldered, right?
