Switchable power source
Us Boxster owners are too poor to buy GT2/Turbo wiring diagrams. What is it you want to do and do you need a constant 12 volts or switched? And, why can't you use the cell phone connector since it has constant and switched 12 volts. Jeff
You pull off the carpeted trim panel and there will be a black unused connector with 4 wires. There is a ground, constant, and switched 12 volts. We use it for MP3s, V1s, and other things that need switched or constant power. Jeff
