Hello All
I have a Cayenne and the last 2 days it has faulted on warning saying "Check Fog Lamps" even though the fog lamps are illuminated. It has never faulted like this before even though they are aftermarket HIDs.
And this morning i had the lights off and it still faulted out...is this a job for the PIWIS tester/Dealer
it still will not go away..ideas? ;)
The fog lamps in the back are o.k. ? If yes reinstall the original lamps and trey again, i don't believe that an O.P.C. will start working on non original items.
i will try orignal bulbs just a little cold out here in the northeastern US :)
its just odd that the bulbs havnet done this for 2 yrs and started now.
Can be a question of resistance or consumption in extreme temperatures like you said.
i had them installed on mine even though the advertising claimed that it would not set off the fault code and it would take 15 minutes to set off the code so i removed them. Regular bulbs produce much better light with my new aero kit lamps anyway
gixxer
i have the same set up as you (AERO KIT) what bulbs did you use for the fogs?
