I have a 2004 Cayenne S, and have been having a problem with the driver's side dip light going out. If i pull the head light out and put it back in place it seems to work for a couple of days. Has anyone else had this problem?
You can bend the male connector pins a little, to have a better contact in the female connector.
It is mostly bad contact between the connector pins, you can always start with that.
I had this same problem on my 05'S. It went to the dealer 3 times and they "solidified the connection". It wasn't until the 4th time that I went back and demanded that they start replacing parts. They replaced the Xeon bulb in about 10min and it hasn't happend since. I recomend that you go to the dealer and let them know this. My dealer stated that Porsche and VW are "aware of this problem" on all of their SUVs.
