TP, why do you like this one better? I got the PCar one through sunset for $15 and it looks identical. Is there a difference?
Dell
Edited by LVDell
Hazet version is on the left. Mann on the right. Either does the identical job.
Over the years we have done many, many oil and filter changes at our work on cars days. We use a 3/8" drive ratchet with an 8mm bit on the end to remove the drain plug. The Mann filter wrench requires a 27mm socket to turn it and at that size your are into 1/2" drive. Hazet filter wrench is 3/8" drive.
It simply takes too much time to switch ratchet drive sizes, and then torque wrench drives, as you have to slide in and out from under the car.
Thanks TP! That is exactly the problem I was having. Not really a problem, but more of a pain in the tail. Oh well.
