Camshaft Allocation.
My Boxster has several CEL codes all related to right Bank cylinder 1-3. Engine is at TDC cylinder 1...After removing cam cover for the 3rd time I see that the timing marks on the intake camshaft have jumped 1/2 link...
The bright chain link on the exhaust (lower) camshaft is directly above the dot on the exhaust camshaft. The bright link on the intake camshaft is 1/2 link out...
I assume that the timing marks should always be the same position no matter where the varia cam is?
-I assume this could cause a PO341 and a missfire in bank 1?
-What could cause this to happen?
What do you think??
