So here we go...
Over the last few months I've notice a slight tapping noise from the engine at idle,
when I rev lightly the tapping speed's up?
I do a lot of slow stop & start city traffic driving which does not help I know. But it also sometime comes after start up from cold?
So I've had the noise from a cold & warm engine
It's a like a similar problem I had in my 986 Boxster a few years ago, while half way through a euro road trip it started
to make this tapping noise which sounded like a Water Pump problem, but ended up been from a part called a BELLOW's
I'm thinking it's either the water pump,the drive belt, spark plugs, or bellow
Ah who am I kidding I have'nt a clue???????
Anyway all thought's much appreciated.
Thanks in advance
2001 996 C4 CAB.6sp 71,200miles
Edited by JamesD
So here we go...
Thanks in advance
I had a very similar problem with my 996 C4 CAB 66kmiles. It turned out to be the Exhaust pipe was slightly loose and when I gave it more gas or revs it became more apparent. I had someone rev the engine slowly in newtral and then I went around to the back of the car and could really tell that was the problem. Good luck and let me know how it works out.
Regards,
Brian
