Rear door/hatch won't open from outside
I have an 04 Cayenne S. Today I was getting help loading some stuff in the back, and the guy from the store that was helping me shut the hatch (not glass) partially, so that the door wasn't all the way shut. Instead of opening the door again and closing it, he held the release mechanism down and rocked the door open and shut a few times. Then the door switch wouldn't work at all. The glass release button works. I was able to manually open the back gate with the release from access spot on the inside of the door.
So at this point the rear door/hatch won't open from the outside. The remote release for the rear glass (by the gas release at the driver's door) won't work now either. The gas release does. When you push the remote release for the rear glass, there is a clicking sound from the fuse box. It made the clicking sound a few times, but then stopped.
Any suggestions? The manual doesn't list these buttons for a specific fuse, does anyone know what fuse these would be part of?
Thanks in advance,
Peter
