Slotted rotors for C4S?
I measured the front rotors on my '02 C4S today and they are just below the min thickness of 32mm. Can anyone recommend a source for reasonably priced slotted rotors for this car? By reasonable I mean about the same price as OEM.
TIA
Try www.brakeperformance.com for slotted brake rotors. Their prices are for a set of 2, so the prices may seem high. C4S brake parts are really expensive due to the big red brake system. I just replaced by brakes/rotors/sensors/bolts/etc with PORSCHE OEM and it ran $1500 at my indy.
I decided to stick with OEM as I've had good luck so far. Rotors were $153.92 each from Sunset Imports. Caliper bolts, spring kit etc were another $60. Will do the work this weekend.
